Hi everyone! I have a 1992 surf 2.4 td which starts bad from cold. engine misfires and smokes a lot with loud diesel knock and then clears fairly quickly. Any ideas guys??
Bad starter
Try the search button it i think there's quite a few pics and info there.Originally posted by happyeater View PostThanks for a fast reply. Tried glow plugs but not injectors. Do you have any info on the configuration of all the small vacuum pipes in the engine bay?
http://www.apspropertyfix.co.uk/
you might want to check the buzz bar (cant think of its proper name) cos if it doesn't have good contact then it wont work so well. If you do go down the route of new injectors then get hold of diesel bob, it will set you back a couple of ton but well worth it. you could try some redex or forte (from roughtrax).
good luck getting it sortedit never rain it pours! glad I got the 4X4
