how do you remove front bumper
Front bumper
Originally posted by markyMy bumper has pushed back about an inch from that slight bump i had the other day so this will be my job for the weekend. is it likely that ive bent some form of bracket in the bump??
you're probably OK, the brackets can move on the mounts as the holes are elongated. You may have bent the brackets that attach the ends to the wheelarch but these easily bend back. The other 4 bolts are on sliding mounts.
Originally posted by markycheers andy, i noticed it today the end caps on the bumpers are out of line with the wheel arches, so is it a case of slacken bolts & pull it back or shall i remove the whole thing.
Originally posted by JimLTake off the orange lense by unscrewing 2 screws, pull the small unit fwd, refit the lense, put the unit back through the hole sideways, makes a great handle for lifting the removed bumper!(\__/)
