I am taking a set of L/C springs off the back of my 2.4 and putting them on my 3 litre.
I have disconnected the rear brakeline, removed both shocks, removed the panhard rod and i cut the handbrake cable guides off when i fitted the springs to the 2.4.
So the question is, will i still need to use the spring compressors, or should the rear axle/diff drop low enough to remove the springs as there is nothing holding it up?
Many thanks in advance!!!
