thermostats
  • thermostats
    found this interesting, http://www.coolingcomponents.co.uk/O...RCHNG_2004.pdf
    can anyone confirm the part no for a toyota stat on a 2.4?
    If it's 90916-03072 by a process of cross referencing and searching it seems that this stat was used by VW, Arrow, Chrysler, Daihatsu, Colt, Ford etc etc etc...
    but what i found more interesting was the motorad part # 240-88 , if you look at all their part #s the suffix seems to be in the 75-96 range, incedentally the surf one has a suffix of 88 which i believe happens to be the temperature it opens at, so if there were to be one with a part# instead of 240-88 it had a lower suffix, say 240-82 would it be fair to say that the chances are it's gonna fit but open earlier?
    I don't wanna get into the pro's and cons of a stat that opens earlier...
    ...yet? Just thinking out loud feel free to do the same.
    Last edited by nero279; 8 November 2007, 13:14. Reason: changed title from stats to thermostats at nevs request
    =SOLD UP!=
    if........
    asmany have done and disconnected the egr valve,what effct would this have on overall engine temp.the thermo used must be done so with regards to the engine as a whole,so for instance engine mods of a serious nature require ,generally, more cooling.maybe......
    this is a good thing,but will the engine temp struggle to be attained
    or
    will the act of opening the thermo earlier allow overheating to happen on a hot day,by not restricting the flow through the rad and not allowing it to be cooled sufficently?
    Non intercooled nothing.
      90916-03072 now supersedes to 90916-03099. A 240-82 will probably fit and as you say, will open earlier. I use an aftermarket Tridon which is a TT322 -180. The 180 being farenheit which converts to just over 82 degC. I also believe there may be a Toyota 82 degC thermostat but will have to do a search.. I think a number of Aussie owners have changed to either the Tridon or one of a number of brands of 82degC thermostats.
      A couple of threads where thermostats are discussed. Both the 2.4 and 3Ltr.
      http://www.toyotasurf.asn.au/forum/v...ghlight=tridon
      Nev
        Changing the topic to "thermostats" will help with future searches.
        Nev
          so continuing in a similar vain i've now cross referenced 240-82 and 240-77 back to original toyota part #s
          giving a 77 degree stat pn# 90916-03025 originally fitted to a 3K engined 1200cc LiteAce production date 7105-7203
          or 82 degree stat pn# 17570-74001 or 90916-03002 or 90916-03054 or 90916-03056 or 90916-03057 or 90916-03083 and more, the only ones that appear to show up at all on the EPC version i've got though are 90916-03054 and 90916-03083 and where the first shows up, the 2nd is given as a substitute, and they appear to have been used across a whole range of vehicles.
          Whether it only seems to be these 2 part no.s show up on the EPC because they have superceded previous part number or if there's been an erooor or discontinued parts i don't know. I've only got the information i'm sharing so if anyone can deduce anything else from it feel free.
          You can cross reference back to other applications rather than just manufacturers part #s by searching this PDF http://www.coolingcomponents.co.uk/Thermostat_2004_.pdf
          =SOLD UP!=
