injector pump still leaking
  • injector pump still leaking
    so, i ordered the pump seal kit from milners i changed the top seal and 'o'ring,
    but i still have a major leak, from the rear of the pump it appears, theres 4 allen bolts on the back of the pump which fasten the distributor block to the main pump body(i think), now my leak is either between the two faces,or from the stop solenoid
    now im guessing the largest seal that was in my seal kit goes between the main bodyand the distributor block , is this correct? and can i remove the mentioned allen bolts and change the seal whilst the pump is still on the car, and is it a straight forward job?
    Grant
    I did and also the O ring on the part with the electrical connector on the top. Still leaks on the Veg.
      Be careful in there thats where tony said the timing for the pump is ........Thats going into diesel specialist realms
      www.daemon4x4.org
        That's the same place mine is leaking from, and will need to be removed from the vehicle and refurbished at a pump specialist.
        Rob
        Still working for the man!
          mmm, still pondering over this, and i just had a thought, it looks like the top seal may still be leaking and running around the distributor block, now
          when i removed the top cover yesterday it had a rubber seal and a paper gasket, surely it shouldnt have both should it?
          anyway i renewed the rubber and used the old paper gasket, now im thinking take paper one out , the rubber would seal it on its own?
          so do any of you guys have both gasket and seal on there?
          Grant
