anyone know the designated height of the towball to floor cause i just fitted a towbar and it looks a bit higher than the fourtrack i had before
towball height
Just bought a Bradley tow/hitch & the blurb states...recomendation for the centre height of the towball or jaw should be 430mm + or - 35mm when towing vehicle in the laden position.Originally posted by Merlinanyone know the designated height of the towball to floor cause i just fitted a towbar and it looks a bit higher than the fourtrack i had before
So it's more to do with what you're towing & what the noseweight is.
You can get a plate which has different height settings on it.
My towbar seems high.....& if I hitch a small trailer on it makes no appreciable difference....but with the caravan...not too bad.
It might be worth getting the height adjustable drawbar, but it'll be a bu**er off road
Hi MerlinOriginally posted by Merlinanyone know the designated height of the towball to floor cause i just fitted a towbar and it looks a bit higher than the fourtrack i had before
The height of a Bailey Pagent is 432mm= 17". That is a message I recived directly from Baileys help line. I asked the question about a month ago.
The chassis type and wheel size are quite commonly use.
Hope this gives you some direction.
Geoff.Rubblebags (Geoff).
thanx geoffOriginally posted by rubblebagsHi Merlin
Geoff.
All work and no play
towbar height
try these www.towsure.com drop plates are only £2.75 for the 3"and 5" multi drop plate or cheaper for single drop just got one myself good service. ady
[B]keep on surf'in[/B]
tow ball height of 17 "
