Hi all. Its my first time here and was looking for a little advice. Have just purchased a 2.4 surf (1993) with head probs. I.ve changed the head for a brand new one from a good supplier and i've fitted it myself so i know its on correctly.
However, On starting to bleed the coolant system I have noticed that when the system is under pressure I am getting a small leak and steam coming from the general area of the inlet manifold. Its not from the head but i did notice small water pipes from the thermostat housing running out of sight under the inlet manifold...Does anyone know whats at the end of said pipes so I can try and rectify the problem so I can get the surf on the road.
Also if anyone would like advice on any aspect of replacing the head as a DIY job please ask and ill help as much as I can!!!
Many Thanks: Phill!
Many Thanks: Phill!
