I need to balance up the space between the top of the wheel and bottom of the wheel arch. The gap on the passenger side is 15cm, drivers side is 16.5cm.
What should the gap be without any suspension lift??
Which way do I need to turn the adjuster bolts??? I ask as at the moment I can't get the driver side nut to move without a lot of noise and don't want to break anything!!
