Some may remember a few weeks ago a couple of links came up about a modification to the factory temperature gauge.
(http://www.toyotasurf.asn.au/forum/v...ic.php?t=14717 & http://forum.ih8mud.com/showthread.php?t=64252)
I decided to give it a go, but had trouble finding resistors of the values mentioned. I ended up with 47ohm and 100 ohm 3 watt wire wound resistors encased in plastic and concrete insulators from maplins.
The mods been done a week now, and first impressions are that the guage is definately moving around a lot more, i'm taking this as meaning that it is giving a truer reflection of the actual engine/coolant temparature, as it seems to be doing what i would expect.
**It's worth noting that I have been running without a thermostat so i guess this could affect the gauge readings and they may calm down a bit once i re-fit a thermostat**
First time out it concerned me that the gauge seemed to take a long time to move at all, this could well be due to having no thermostat fitted.
I'm not 100% happy with the 'normal' position the gauge seems to assume when idling, or driving at low revs, it seems to sit on the far left of the gauge only 1 or 2mm right of the first mark.
Also when driving at high revs/ high speed the gauge quickly moves to the right hand side, which i guess it should, but i fear a sustained high speed ie)motorway driving might well cause the gauge to sit permanently in the red, i haven't been on the motorway since the gauge has been done but will see what happens on sunday.
After a run then a brief switch off (say 5-10 minutes), when you turn the ignition back on the gauge goes up into the red, the electric fan also kicks in. Guess this is due to heatsoak, and i'll be happy if the gauge goes into the red when or just after the electric fan kicks in although i would like it to go into the red at a slightly higher temparature than the fan kicks in.
I haven't bench tested it and don't plan on doing so.
