help.....
my surfs out to get me in the pocket...
for some reason once it warms up,and only at slow speeds and with the front wheels turned the rear wheels start biting and shuddering ,mainly at junctions and when trying to park,
if up try to reverse into a parking spot in reverse then you better put a bit of wood in your mouth and bite down....
i have cleaned the brakes up and let of the handbrake tension a little but there was a clunk and its started again...
its not stuck in 4wd,uj looks ok,diff,gearbox and transfer box all have oil..
i have had the diff plug out and rocked the wheel back and forward all looks ok!!
could it be the tensioner buggered on handbrake or ....THE LSD DIFF.....still ?
any ideas ??please??
