Just been out and checked coolant, i took rad cap off and to my horror it was dry, so i set the heaters to hot and filled it back up and ran it for 15 mins. my expansion tank is 3/4 full with red fluid/coolant... took about 2.5/3 ltrs of water. Now i dont have any obvious leaks, so is it likely to be my rad cap not holding pres
ure or thermostat ....or should i start worrying about the head.
Edit : am i better getting gen toyota thermostat from RT or the one from milners and also the same with rad cap ??
ure or thermostat ....or should i start worrying about the head.Edit : am i better getting gen toyota thermostat from RT or the one from milners and also the same with rad cap ??
