Over the past 1/2 weeks i have noticed that my left foot seems to get hot quite quickly, i know the atf is due for a change but is there anything else that i should check for that might cause this ?
Hot left foot
Originally posted by horse_fleshOver the past 1/2 weeks i have noticed that my left foot seems to get hot quite quickly, i know the atf is due for a change but is there anything else that i should check for that might cause this ?
Possibly a missing heat shield from the exhaust downpipe, it's gets very hot there 'cos it comes straight out of the turbo.
If you look under the rear seat, you'll find one slipper (for right foot) and one open toed sandle (for left foot).
Standard Toyota equiptment for auto's.
Rob
Still working for the man!
it is probably like you said the atf needs changingOriginally posted by horse_fleshyea, i had read before on other post that i can get quite hot especially when towing and/or going up a long hill, but this just seems to have come on in the last few weekshttps://www.facebook.com/groups/henpals/
Strange thing is that I've noticed the exact same thing has started to happen to me. It began only a few weeks ago. It's not massively hot, but my foot is noticeably warmer than usual. I had a quick look and the only thing in any proximity is the exhaust pipe. No signs of anything wrong, so I'll just see if it gets any worse.Originally posted by horse_fleshOver the past 1/2 weeks i have noticed that my left foot seems to get hot quite quickly, i know the atf is due for a change but is there anything else that i should check for that might cause this ?
Paul </Slugsie>
Immortal.so far!
2nd GENS have an oven under there for JACKET POTATOESOriginally posted by SlugsieStrange thing is that I've noticed the exact same thing has started to happen to me. It began only a few weeks ago. It's not massively hot, but my foot is noticeably warmer than usual. I had a quick look and the only thing in any proximity is the exhaust pipe. No signs of anything wrong, so I'll just see if it gets any worse.
Excellent, must remember to stick a couple in for my drive to work tomorrow. That should stave off the hunger pangs in the morning.Originally posted by marky2nd GENS have an oven under there for JACKET POTATOES
Paul </Slugsie>
Immortal.so far!
