here is a little strange one for you guys...
on pulling away, gently, or reasonably briskly... usually in a straight line... i get what feels/sounds like I am running over small pebbles. This happens almost every time I pull away, unless i am very generous with the loud pedal. is it something starting to go? bearings? Is it something out of adjustment? I have had a good rummage about, and nothing is loose, tyres are in good condition, pressures are close enough... no major movement ...
Any other suggestions...
