how much do you extend the Panhard rod if you fit l/c spring?
also does Bushwhacker still sell the fitting kit?
if so is it still £40 + postage
tanks
tanks
but hes also right.if you lift your surf using l/c springs and looking from the rear your axle is still pretty much central then your ok however if on the other hand you find that you axle is out of centre by an inch or two.you will need an adjustable panhard rod to correct it.
