Originally posted by cbv8
Convert my 2.0 petrol to 3.0 td an easy swap???
Originally posted by surfensteini could give you a price but it would propably cost more than your surf is worth. try a local engineering company.there should be loads to choose from up north.ohh and you will need to turn down the output shaft from the zf also to mate with the toy transfer case.Cheers,
Chas.
OK MR SURFENSTIEN now you have go me into V8ing my Surf AGAIN could you please tell me how i go about telling a machine shop how to make the said plate cause i an't got a clue Are there any dimentions/diagrams etc written down anywhere that i can download or could you perhaps send me anything that i can take to a machine shop to show them what the hell i am talking about My mate thinks i'm round the bend to even consider this conversion he is a L/R man through and through so no hope really Any help or anymore of your invaluable advice you could give me would be very very very very much appreciated it would indeedy be mateCheers,
Chas.
right ok what you need to do is get an ally plate about 8mm thick that will be big enough to go onto the toy transfer case stud pattern.(input side.)mark out the position of the holes including the output shaft hole,drill these out and mount the plate to the trans case.make sure you have a good fit.next get an engineering company to make you a sleeve that will fit onto the zf output shaft and also onto the toy transfer case input shaft.weld the sleeve on to the gbox output shaft making sure it is on straight,if you dont get it straight then you will knacker a bearing.obviously dont weld the sleeve to the transfer case shaft.mount the transfer case with the plate on to the end of the zf g/box again make sure everything is lined up and true.then get someone to tack weld the plate on to the end of the g/box shaft.(make sure you remove the output shaft oil seal first otherwise it will melt.)then remove the transfer case when you have enough tacks on there and then seam weld the plate to the output casing of the g/box.then fit a new seal on to the shaft(ally welding is a right pig of a job so unless you know what you are doing get someone who knows what he is doing to weld it up.hope this helpsLast edited by surfenstein; 9 September 2007, 20:52.www.overfab.uk
Originally posted by surfensteinright ok what you need to do is get an ally plate about 8mm thick that will be big enough to go onto the toy transfer case stud pattern.(input side.)mark out the position of the holes including the output shaft hole,drill these out and mount the plate to the trans case.make sure you have a good fit.next get an engineering company to make you a sleeve that will fit onto the zf output shaft and also onto the toy transfer case input shaft.weld the sleeve on to the gbox output shaft making sure it is on straight,if you dont get it straight then you will knacker a bearing.obviously dont weld the sleeve to the transfer case shaft.mount the transfer case with the plate on to the end of the zf g/box again make sure everything is lined up and true.then get someone to tack weld the plate on to the end of the g/box shaft.(make sure you remove the output shaft oil seal first otherwise it will melt.)then remove the transfer case when you have enough tacks on there and then seam weld the plate to the output casing of the g/box.then fit a new seal on to the shaft(ally welding is a right pig of a job so unless you know what you are doing get someone who knows what he is doing to weld it up.hope this helpsCheers,
Chas.
Originally posted by SpitfireCheers,
Chas.
Originally posted by cbv8Nice one mate what your saying really is i need an old Transfer box to use as template and yes i agree ally is a ba**tard to welg so that will be a job for my mate i reckon Thanks again Surfenstien i really appreciate your help advice but is there anything else in need to worry about with this conversion all i can think of at mo is sorting e.mounts/exhaust/w.pump/alt brkt/rad? The ZF box will have it's own fluid cooler NOT a stupid rad intergrated thingy so no worries there will be doing away with a/c as it's buggered anyway and engine will have a leccy fan. Then comes the fun bit the twin BIG bore exhausts that is my mates profession so i am well away there if you have anymore advice on what e.brkts etc i need to use or is it easier to fabricate my own from scratch any diagrams or pics very much appreciated as alwayswww.overfab.uk
Originally posted by surfensteinthere,there i know you were.its ok even the best of us get it wrong sometimes.Cheers,
Chas.
Originally posted by cbv8Never mind all that read my previous i am after extracting ALL the info i can from your SURFENSTIENV8BRAIN while i'm on a roll so get back to the original blooding questions and answers PLEASEwww.overfab.uk
Originally posted by cbv8Never mind all that read my previous i am after extracting ALL the info i can from your SURFENSTIENV8BRAIN while i'm on a roll so get back to the original blooding questions and answers PLEASELast edited by cbv8; 9 September 2007, 22:34.Cheers,
Chas.
Originally posted by cbv8Sorry about the previous post i think we are getting crosses posts i know what you mean about forward facing downpipes i have the same problem/conumdrem with my RV8ZF to my Stag God i am reading your answers as i am writing my questions is that weird or what is there a delaaaaaaaaaaaaaaay on this forum or is it me being inpatientwww.overfab.uk
