Can anyone help me please with a Part No for the Anti-roll Bar bracket in this picture. It's for a 1992 SSR-X 2.4LTD.
Anti-roll Bar
Assuming it's the same as my 1990 then the part no's are 48823-35060 for the bush retaining cover and 48815-14140 for the bush. If you let me have your model and frame no's I could double check this for you.Roger
Thanks both. I have given the Frame No/Model No to a local Japanese Car Parts shop. Sounds like they are going to get the part from the nearest Toyota dealer anyway (about 25 miles away). I just thought it would help them positively identify the part. I'll get the info off the plate anyway and PM to you Roger.It's only a hobby!
Its for my ex-truck, the 4RunnerOriginally posted by GamedawnOf course, you could always take the rear bar off and solve the problem once and for all. Cheap solution too
And yes, the roll bar is removed, to be honest, with LA S' rear coils, I don't think it needs it, but want to put the truck back together properly.
Did anyone get a difinitive part no from toyota for these?Originally posted by blue surfi have fixed the same problem on my surf. £7.64 from toyota, and ten mins. with a 12mm spanner. must be big air over all the speed humps around here
I need one!
Is it likely that that broken clamp is whats causing all my horrible suspension noise?Last edited by carbonman; 13 March 2004, 18:35.
