Urgent Help Needed
  • Urgent Help Needed
    Hi guys and gals i am replacing the shocks on my 3rd gen but cant get the sensor of the top of the shocks on the rear has anyone got any ideas please cheers mat
    Undo the 2 ten mil nuts. Take it off and undo the wiring connector. Bit fiddly, but do able.
      i'm not sure if they are the same on the 3rd gen Clay
        It looks like a similar system to the earlier models. Earlier just have the two bolts on the cap. Remove them and slip off the cap. Shock nut is underneath. Diagram below may help.
          IIRC the actuators are just clipped into a holder. The holder being a cup which is secured by the top damper nut.
          Its a while since I changed mine but I think I simply prised then off, I wasn't worried about damaging them as they weren't going to be reused.
          The pic posted by Nev seems to support what I remember, ie no securing nuts, just clipped on.
          Maurice
            A big thank you guys i can have another go at it now
