3rd GEN SERVICE INFO
  • 3rd GEN SERVICE INFO
    3rd GEN None intercooled
    Toyota Surf 4x4 3.0 TD KZN185 Technical Data
    Lubrication Specifications and quantity
    Engine Oil 1KZTE engine 10W/30 or 10W/40 7.5 litres with new oil filter
    Manual Gearbox SAE 75W/90 3.9 Litres drain & refill
    Automatic Gearbox ATF Dexron III 2.2 Litres drain & refill
    12 Litres dry fill (from rebuild)
    Transfer Box SAE 75W/90 1.4 Litres drain and refill
    Front Differential (satndard) Hypoid gear 80W/90 2.8 Litres
    (L.S.D) Castrol Hypoy 90 LS oil 2.8 Litres
    Rear Differential (standard) Standard gear 80W/90 2.8 Litres drain & refill
    (L.S.D) Castrol Hypoy 90 LS oil 2.8 Litres drain & refill
    Brake and Clutch fluid DOT 3 type to level
    Cooling system coolant Ethylene-Glycol base 10.00 litres without rear heater
    (drain & refill for both) 11.00 litres with rear heater
    Power steering Dexron III to level
    General vehicle specifications
    Tyre pressures size -265/70/16 front 28-30 P.S.I
    rear 30-35 P.S.I
    Air conditioning gas
    Fuel capacity Diesel 65 litres
    Towing capacity 2500 kg (with trailer brakes)
    Horsepower 1KZTE engine 130 HP @ 3600 rpm
    Gross vehicle weight 1850 kg
    Idle speed Manual 700 rpm
    Automatic 800 rpm
    Please note all the information and technical data has been given as a guidance only and should be checked with Local Toyota Dealer.
    Sorry marky, don't mean to shoot you down, but there's some errors there...
    Engine oil is about 7 litres with filter, about 6.5 without.
    Front diff with ADD needs SAE 75W-90 GL5.
    Auto gear box drain and fill is 4 -5 litres, depending how much of a hill you've got it on.
    Rear diff is SAE90 GL5 (unless you live where its -18 degC, then its 80W90 GL5).
    Official tyre pressure is 2.0 BAR or 29 PSI (I know most run slightly higher).
    Fuel tank on mine is either 70 or 71 litres (and the EPC only lists one part number for all models).
    I can't comment on the rest as I don't know off the top of my head if its correct or not.
      I copied it from Elsewhere & i was waiting for someone to correct the SPECS
