3rd GEN None intercooled
Toyota Surf 4x4 3.0 TD KZN185 Technical Data
Lubrication Specifications and quantity
Engine Oil 1KZTE engine 10W/30 or 10W/40 7.5 litres with new oil filter
Manual Gearbox SAE 75W/90 3.9 Litres drain & refill
Automatic Gearbox ATF Dexron III 2.2 Litres drain & refill
12 Litres dry fill (from rebuild)
Transfer Box SAE 75W/90 1.4 Litres drain and refill
Front Differential (satndard) Hypoid gear 80W/90 2.8 Litres
(L.S.D) Castrol Hypoy 90 LS oil 2.8 Litres
Rear Differential (standard) Standard gear 80W/90 2.8 Litres drain & refill
(L.S.D) Castrol Hypoy 90 LS oil 2.8 Litres drain & refill
Brake and Clutch fluid DOT 3 type to level
Cooling system coolant Ethylene-Glycol base 10.00 litres without rear heater
(drain & refill for both) 11.00 litres with rear heater
Power steering Dexron III to level
General vehicle specifications
Tyre pressures size -265/70/16 front 28-30 P.S.I
rear 30-35 P.S.I
Air conditioning gas
Fuel capacity Diesel 65 litres
Towing capacity 2500 kg (with trailer brakes)
Horsepower 1KZTE engine 130 HP @ 3600 rpm
Gross vehicle weight 1850 kg
Idle speed Manual 700 rpm
Automatic 800 rpm
Please note all the information and technical data has been given as a guidance only and should be checked with Local Toyota Dealer.
rear 30-35 P.S.I
Automatic 800 rpm
