Hi all, autobox has an intermittant fault which seems to be caused by the speedo, when turning on the ignition speedo flicks up to 45mph. when you drive off it tryes to go in 2nd gear then ok until 4th which only drops in when you back off the gas. have changed the solenoids in box but no joy.
does the ecu control the gearbox or is there a trans control unit & where is the flippin thing!
or is it the speedo pickup? any help would be gratefully recived thanks.
