Following my brown-trowsers moment on the way home yesterday, I've had a look under the car. All seems OK, except the idler arm. It seems loose...
Video of the idler arm
(That amount of play was without any movement in the other wheel!)
I'm guessing that that would explain the sudden lurch to the side, especially if it hit a small lump first?
First question, how much play should the idler and pitman arms have?
Will the idler arm from a 92 2.4 fit my 95 3.0? Milner part numbers suggest that they will. If that's the case then I'll just borrow the ones off my 2.4 which is sitting un-used on the driveway.
Also, does anyone know if there is much difference between Milners and Roughtraxs Idler/Pitman arms? There is a big price difference between them. I replaced the Idler arm about 8 months ago, and bought it off ebay, seems it wasn't a good one.
) etc. Didn't budge an inch. In fact I've knackered the end of the bolt that connects onto the steering arm with all the hitting, so it's going to take some creative work to bolt it back together.
