I have a Lean
  • I have a Lean
    Ok iv had a lean on my surf on the front drivers side wheel its as though the camber is out with the top leaning inwards iv had a good look and everything is strait under there any ideas for a cure as its starting to burn front tyre away now and that = costly if i leave it is there a way to adjust the camber or should i be looking for something worn ?
    !!!My Rice Krispies told me to do it!!!
    Could be a bent/out of adjustment track rod, or a worn steering idler.
    Get it checked by a specialist, not kwik sh1t or the like.
    Mine is the same and has been diagnosed as both of the above, so when I replace them it will have to go in for full camber/caster/toe adjustment, as it has been adujsted twice by the usual goons who don't actually know any more about it than me.
    Rob
    Still working for the man!
      hmmm not doubting as im used to rice rockets not 4x4 but track rod usualy controls toe as apposed to camber dosent it ?
