Okay I am after some advice. Think I need to buy some new shocks as the front end has got very bouncy, But which ones, Can someone point me in the right direction
Shocks
ES9000s are harder, thats all, not better.
IMHO if you are gonna use your truck off road, you'd be better with the softer ES3000s. As Richard has said, combined with LC80 springs, the ride is pretty good.
Having said that, I've still got the original Toyota shocks up front. When I change them, it will be for ES3000s, or a non-rusting equivalent!
You cant change the settings on aftermarket shocks.Cutting steps in the roof of the world
Okay thanks for the advice a full set of ES3000 are on there way. Anything I should watch for when fitting ? I hope this will get rid of the rattle noise that comes from the jeep every time I go over a bump and stop the rodeo show every time I brake I feel like Zeberdee with all this bouncing.
just remember to tape up the ends of the cables going to the old shocks so not to let water inOriginally posted by MAD MANXMANOkay thanks for the advice a full set of ES3000 are on there way. Anything I should watch for when fitting ? I hope this will get rid of the rattle noise that comes from the jeep every time I go over a bump and stop the rodeo show every time I brake I feel like Zeberdee with all this bouncing.https://www.facebook.com/groups/henpals/
Yes you would be right. You have to remember mine is not an import but UK model. or should I say No Frills model. I even had to modify it to put the dash cup holder in, Dodgy cheap skate UK models !!Originally posted by stormforce1067i take it you ain't got the adjustable hard soft swith for the shocks on yours then.
my apologies i must need my bloomin eyes tested cause i have only just noticed in capital letters in your profile your vehicle details...what a plonkerOriginally posted by MAD MANXMANYes you would be right. You have to remember mine is not an import but UK model. or should I say No Frills model. I even had to modify it to put the dash cup holder in, Dodgy cheap skate UK models !!https://www.facebook.com/groups/henpals/
