i noticed when i first start the car with the aircon on or turn it on when driving at over 30mph there is a screech (like a fan belt screech)
when i looked under the bonnet i have found it is the aircon pump pully
when i rev the engine the centre of the pully stops turning screeches then starts to turn again when the revs drop
is there a fix for this without having to buy one of these? http://www.toyotahilux.com/?doc=16&cid=152&vid=930
is there any way to adjust the clutch at all?
there are a couple of second hand pumps complete on ebay at between £20-£30 each but im concerned the problem will return with second hand
edited to say that the belt could do with tightening up but its not that loose
cheers in advance guys
