Hi have done searchs on where i can source said seal kit. From what i can see i cant get them. Does anyone know anything different? Thanks
turbo seal
if your on about the gaskets for the oil feed and return etc then you can get them from Toyota.Just give them the chasis numbers etc and they will order them for you.If you have any trouble getting them give me a ring on 07974183876 and i will try to sort them out down here and send them to youOriginally posted by drunkmonkeyboyHi have done searchs on where i can source said seal kit. From what i can see i cant get them. Does anyone know anything different? Thankshttps://www.facebook.com/groups/henpals/
We took the air inlet off the turbo and revved the engine. You could see oil flying off the impellor blades and coating the inlet. It then went on its merry little way into the engine.
The seal/s we need are the turbo oil seals to stop the oil getting into the air flow and of course the oil supply and drain pipework.
Turbo, hub bronze bushes, propshaft, idler arm and various ball joints!
Looks like my garage will be home to a surf for a few days!!
TB
Originally posted by OldDrunkMonkeyWe took the air inlet off the turbo and revved the engine. You could see oil flying off the impellor blades and coating the inlet. It then went on its merry little way into the engine.
TB
The oil in the intake tubes is normally from the breather tube on the rocker cover. The oil vapour condences in the tubes and eventually dribbles out the rubber elbow on the turbo or gets sucked into the intake.
An oil catch can will virtually eliminate this.
. great work!
