just bought a fuel heater from Germany, and it's based on a heat exchange with my coolant water. But there are also two glow plugs which do the heating while the coolant gets up to temp. Also provided is a fancy switch to shut the thing off if I choose to run normal diesel. Now I've read the instructions provided here http://www.kopany.de/energie/einbau_...z_saverbee.htm which make some sense (it's handy to read and write bad english sometimes) but I'd just like to run through a few points before I go mad. Attatched is a pic of the system and notes as to what I think each part does. As you can see I'm not sure about the I'm not totally sure where the red wire to the switch goes too, I'm guessing it's a positive feed, but not sure where from. If anyone can help then many thanks
