What do all these angles mean and where can they be mesured from?
93' UK 4Runner (from Toyota dealer)...............
(all in degrees, can't find the key for it)
Camber.....0.10 to 1.10
Caster......1.10 to 2.10
Toe..........0.03 to 0.15
Inc. angle...12.35
SAI............11.55
I appreciate that they are all required for the tracking but how do you measure them ? Is there no quick and dirty way of checking between wheels to see if the are parallel ? Help ?
Reason behind this I had mine tracked by a local Universal Tyre place and they laser tracked it ?!?! Anyway upon driving away the car pulls to the left as before. What could be causing this and how do I correct it apart from the Toyota stealers ?!!
cheers
Inc. angle...12.35
cheers
