So having read a few bits and pieces on the site I went and measured the distance between the middle of the wheel hub and the bottom of the wheel arch and lookout its only 20 inches, the accepted wisdon would seem to be this should be 22 inches ( that is what it is on the front by the way ), the wheels look like OE and are fitted with 265/70 r15's,
so the question is do I need new springs ( it would appear that way ) and should I be doing the shocks at the same time, I have seen what the price of the springs are from milners but I may look for some other options, is it worth replacing with electrically adjustable ones ?
also how big a job is it to just do the springs, is it doable by a bluffing amateur with the back up of a large forum of helpers ?
all wisdom on the subject gratefully received ?
Forgot to mention its a 93 SSRX 3.0 limited
with no problems with the hoses...
