Rear Axle
  • Rear Axle
    Hi everyone,
    A few weeks ago I start to feel a bit of vibration through the truck, at the time I couldn't get any idea where it was coming from now I have a rumbling noise from the rear axle and when I have jacked it up and turned the wheel there is a good bit of free turn both ways (both wheels) before it actually turns the opposite wheel and the other wheel is turning the same way instead of opposite direction. the internals all sound really rough and loose when the wheels are rocked back and forth.
    Is the diff knackered?
    Any ideas of costs involved in replacement.
    I've never done anything with diffs before so know nothing about them.
    Regards
    Mark
    sounds like a poorly diff mate, but just to be sure check the universal prop shaft joints, just hold both sides of the joint and twist, there shouldnt be any movement.
    TeaM BOFA4x4 Mac 2008
    www.bofa4x4.com
      Thanks for the fast reply.
      I've just checked and the rear UJ is knackered, flopping about like a... well like really floppy thing .
      Still not sure about the diff.
        wheels turning same way shows that the diff is a limited slip differential,
        however, if you have a 163,000 mile 4runner like me, the limited slip bit wont be working anymore!
        but functions like an open diff,
        I get a bit of slack in system before other wheel turns, but no serious vibration - so most likely to be that UJ joint on the prop that is the culprit, and much much cheaper to replace than a diff! - parts around £10
        Landcruiser Colorado
        Sub. Forester
          Yup the rear UJ is totally gone broken into 2 completely seperate parts.
          Is it fairly easy to replace?
          I have 142000 on the clock, so if the wheels are turning together it likely the LSD is still working?
          That would explain the the arse out action in the wet weather.
            yes UJ normally easy to replace - best to do a search on these forums to find a guide
            the wheels on my truck both turn same way, so there is some friction left in clutch plates,
            BUT if one back wheel jacked off ground, or in mud or snow, and other one grippy ground, the truck goes nowhere!
            the wheel in air or slippy surfaces spins, if LSD working properly some of the power should be transferred to grippy wheel
            so clutch plates too worn in my diff
            sometimes there is enough friction in the diff to allow both back wheels to spin in wet, snow or on gravel though
            Sub. Forester
