I've found a newer more comprehensive copy of the Toyota EPC's available as a torrent.
It contains
Japan A1 (07/2004)
Japan A2 (07/2004)
Japan B1 (01/2004)
Japan B2 (01/2004)
Japan B3 (01/2004)
Japan F1 (07/2004)(Frame)
Europe A1 (10/2004)
Europe A2 (10/2004)
Europe B1 (01/2004)
Europe B2 (01/2004)
General A1 (01/2004)
General A2 (01/2004)
General B1 (01/2004)
General B2 (01/2004)
Overseas F1 (10/2004)(Frame)
Overseas F2 (01/2004)(Frame)
U.S.A. A1 (08/2003)
U.S.A. A2 (04/2003)
And of course the EPC program itself
Its not a simple single DVD install like the version some of us are using, but the guy who created the package has included a few movie clips showing you how to unrar (unpack) the files, burn the disc's, install the EPC and load the discs etc. The video's are not brilliant, but will be helpful for those who have not installed or used the EPC before.
I found I did not have the correct codec installed to view the movie clips (sound was OK, just no picture), the required codec can be found at http://www.techsmith.com/download/codecs.asp
You'll need 8.52GB just to install the data, but the EPC does not like to install where it sees more than 5GB of free space. It can also be funny about placing the data on an NTFS drive.
My solution was to create a separate 10GB partition for the data formatted as FAT32. I then installed the EPC program to my C drive and set the data store to the new partition, in this case the T drive. I had to temporarily copy additional files to the T drive to reduce the free space below 5GB and proceeded to install around half of the data disks. I then removed the additional files previously added and proceeded to install the remaining data disks.
Its a bit of a long winded procedure, but if you really want all available info installed it'll do the trick.
Its a fairly large torrent weighing in at 3.44GB and not very well seeded, took me about 5 days (24/7) to get it downloaded.
Hopefully, if a few more of us download it and continue to seed for a bit it will make it easier and quicker for those who follow to get it.
Get the torrent here http://www.isohunt.com/download/16518590/epc+toyota
Note: there appear to be 3 identical torrents available for this, I've listed the one I used as it appears marginally better seeded, plus I'll continue to seed it for a while.
It contains
Japan A1 (07/2004)
Japan A2 (07/2004)
Japan B1 (01/2004)
Japan B2 (01/2004)
Japan B3 (01/2004)
Europe A1 (10/2004)
Europe A2 (10/2004)
Europe B1 (01/2004)
Europe B2 (01/2004)
U.S.A. A1 (08/2003)
U.S.A. A2 (04/2003)
Just started Azureus up.
(I hate opening the firewall up by any degree).
