I have a 92 2nd generation 2.4TD Surf SSR-X
Have a clunk from the front steering/suspension. It occurs mostly when breaking with lock on even if only a small amount, though sometimes just with lock on or sometimes just breaking. Can’t figure out if noise is from left or right.
I have replaced track rod, upper & lower suspension arm ball joints.
I’ve removed the anti roll bar and I’m certain it’s not a shock or wheel bearings.
I can’t detect any play on the upper or lower suspension arm bushes but think this is where the fault is.
How involve is it to replace them?
Are there any special points?
Do I need any special tools?
Can it be done without removing the ball joints?
David
