This might sound a bit simple, but is there a knack to checking the engine oil on my 3.0 D, i warm the engine up, stop the truck on level ground, pull the dip stick, clean it off and re insert, pull the dip stick again and oil is spread over the bottom 2-3" of the stick, and no, its not overfilled
I have to try a number of times before the stick even gives a hint of the level, its almost as if the stick wipes against something on the way in to smudge the reading or maybe the finish of the stick diffuses the oil to give a poor reading.
Any Ideas??
Paul
Any Ideas??
Paul
