Yesterday the window worked fine, but today in the carpark of Homebase (having just bought 2 large bits of trellis
) the tailgate window glass refused to slide down. With 2 people pushing I finally got it open.
At home I had to clamber inside and force it shut with my wife pushing the glass from the outside. The motor is working just fine, it whirs away merrily but nothing is moving at all unless helped by pushing, at which point it will slide slowly about 1/2 way up or down, but not fully open or close.
Can I remove the whole assembly, and what should I clean / oil / grease / hit with hammer to make it work again? I've got the interior trim off and it all looks a bit rusty in there.
Also, how can I trick it into thinking the tailgate is shut so I can work the motor with the tailgate open? Currently it just bleeps at me.
thanks
James
![Wall](https://hiluxsurf.co.uk/core/images/smilies/wall.gif)
thanks
James
