Beautiful day in Ireland. The hinges on my bonnet are really stiff and I sprayed WD40 into the gap where the hinges go into. But how do I get to the actual moving part of the hinges.Any help would be great. Thanks. Colm
Stiff Bonnet
Common problem on Runners and Surfs . Hinge point is up behind scuttle panel and not easy to get at . Apart from removing the hinges and lubricating , I dont think you can get to them to spray anything on them .Left un lubbed the hinges seize and the bonnet gets bent .Best remove bonnet from hinges and then remove the hinges to lubricate . Tricky to remove bonnet with hinges attached .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Taken my bonnet off and on by myself before . Just put some sort of padding under each corner and undo the bolts and then the same the other side . Little tricky but possible .Originally posted by irishoffroadThanks, I didnt think it would be an easy job. A bit of a pain in the ass and ill need someone else to help hold the bonnet. Ist bad of toyota not to have them exposed.
