it sounds like a silly question but as i am a newbie to the 3.0 diesel turbo,i would like to know how long i should warm the engine for before i drive off ,and the same for a warm engine any help would be great thanks
Hi Spuds.
i normally wait till i hear the click of the relay and then start the engine.I then put the radio ans belt on an heaters if needed then i drive off.
Hi Bud, I was always taught as a lad many moons ago to let a Turbo "warm"
(Lubricate & get up ta Working Temperature) TURBO, Not the Engine !!
It could be different nowadays tho ..... but I still give it 5 minutes anyway !!!
There's always a Payback .... You just never see it Comin !!!!
Hi Spuds.
I think you misunderstood the question, or you speed read it and rushed to reply.
From cold, I always let mine tick-over on idle-up for a couple of minutes before driving off.
If the engine is already warm, just start and go.
ihave always been taught to let them idle up and down (before driving and after driving) for about 2-3 minutes each time to allow the turbo to get warm and oil to circulate and then to cool and come down to normal speed...
hope it helps
ttfn
graham
So to Sumarize !!!
The answer to ya ???? is by a majority 2-5 mins warm up time ......
There's always a Payback .... You just can't see it Comin !!!!
So to Sumarize !!!
thats bull, start up and drive off straight away from cold ,so as to bring the oil pressure up quickly the distribute the oil around the system quicker.
more damage is done if left there to sit idle for a few minutes, well known fact that.
