Not wanting to p*ss on anyones chips but I reconnected my EGR the other day and it has actually improved the performance and economy ???????
The engine also runs obviously cooler and seems smoother. I suspect it could have different effects on how the pump timing is set up etc and removing the EGR might alter the mixture settings??? I wonder if anyone has disconnected their EGR and had the engine re-tuned? I don't know about smoke from the exhaust because mine dosn't give out any with the EGR on or off.
I know this subject is often talked about so it may be worth while having a sticky under modifications etc?
Andy
Andy
