This may interest you
  • This may interest you
    I've just started a thread on the Aussie forum and would like some feed back if you guys have any info that would help. It's about 3L head replacement on the 2.4s and which gasket to use. If you have done the conversion I would like info on which gasket (part number if possible) you used and if you know of any differences between the various gaskets available.
    Link - http://www.toyotasurf.asn.au/forum/v...ic.php?t=12436
    I dont think the 3.0 SURF head fits the 2.4 EFI Block.
      isn't the 3l head a 2.8 head and not the 3.0 head.I may be wrong but i'm sure i read that on here somewhere
        Its the 2.8 head i think.
          i just done a search so i dont look stupid or something and get voted again for iotw and found this
          http://www.hiluxsurf.co.uk/forums/sh...light=2.4+head
            3L is the engine code for the 2.8 engine.
            3 is the generation, L is the family
            2.4s are 2LTE (second generation, L type, turbo, EFI)
            3.0s are 1KZTE (first generation, KZ type, turbo, EFI)
            In short Richard, yes, you're right. The 'modified' 2.4 head is just the standard 2.8 head. Preusumably the updating of the design happened during the change from 2nd the 3rd generation 'L' engine.
              hehe, IOTW......
              Trev.............
              A 3L IS the 2.8 motor.
                ppphhhhheeeeeewwwwwww i'm glad i got it right then
                  Originally posted by TonyN
                  hehe, IOTW......
                  Trev.............
                  But its not the 2.4 The point was does a 3.0 head fit a 2.4 not a 2.8head
                    Keep digging......
                    Hopefully any sensible suggestions will get posted on Nev's thread on the Aussie site.
                      Nev wants to know what gasket is used and part no. when the 2.4 head is replaced with the 3l 2.8 head not the 3.0 head
                        Keep digging......
                        hehe.
                          Originally posted by stormforce1067
                          the 3.0 head
                          Which as we all know is a 1KZ/TE, not a 3L.
                            i only remembered about the heads cause i take note of what you say Tony..
                              hehe, IOTW......
                              Trev.............
                              Duly nominated for a fine
                              Break the moths out of your wallet Marky
