help!!!! im in a little renault van while my surf is getting fixed and ive filled it up with petrol it had half a tank of diesel in and ive topped it off ive driven 30 miles since feels normal can i get away without draining the tank if i keep topping up with diesel i need to know quickly thanks matt
help petrol in a diesel
I did that once with a mondeo. Try and empty it all out with a syphon. Then fill with diesel. When you run it again it will smoke like CRAZY till the petrol has been burned away and then when the diesel is pulled through you will be sound. Just don't worry if it starts smoking like mad, keep running it will just be the petrol upsetting the engine. You will have nice clean pistons though.....www.myspace.com/conandoomconan
a long time ago i used to manage a group of texaco filling stations and this was and prob still is a regular occurence. we used to advise filling the tank to the brim with diesel, blast about for a bit up n down the m1 / a38 and then come and refil to the brim. keep topping up every day. always worked, never had any complaints or see that much smoke. advice came to us via local indie car mechanic shop.
however most ppl around our way were tight and only used to fill up with 10 - 20 worth.
