I have a Toyota HI Lux 2.4 1992, Has anyone any suggestions why i am having vibrations on braking, seems to get worse after heavier braking. Have looked at disc but cannot see obvious warping, would appreciate any advice.
vibration on braking
This topic is closed.
look into the brake disc bolt holes, they may have come loose mate, if the disc is coming looe from the hub then whip it off and stick some standard 10mm bolts is, the toyota ones are m10x25 with a 14mm a/f head. but will take a standard m10x25 with a 17mm a/f head. worth putting new thread lock on them as well.TeaM BOFA4x4 Mac 2008
www.bofa4x4.com
