Evening all,
noticed a small fuel leak the other day, seem to be from the top of the injectors, had the surf booked into garage today anyway for them to sort out a very annoying rattle after head change about 250 miles ago.
Mechanic said the leak is from fuel pump ( now p***ing out when engine running and gets faster as revs increase) and would need diesel specialist to overhaul pump at staggering cost (gulp!)
Did a search, and consensus seems to be the top seal, although I can't actually see where it is comming from, as everything is covered in dielsel.
I have the mechanical pump ( NOT EFI) so is it just a case of removing air filter and then top cover and renewing the seal (Milners Kit) or is it more complex or possibly one of the hoses?
Any help appreciated as I would like to have a leak free surf and actually get it fixed permenantly for once.
Thanks in advance.
Taking dog for a walk now, be back later.
Clive.
Thanks in advance.
Clive.
