Have a look at the attached pictures please, and let me know what these bits are for if you can. The first is the red button above the auto box, and the second could be some sort of tool attached to the wheel carrier.
Cheers.
1: Allows you to remove the G/Box from park with ign off etc
2: Place in hinge of wheel carrier when open to stop it from swinging shut and hitting your tailgate
1. Don't push the red button when hoovering the dust out of the gear selector gubbins, unless the handbrake is on, or you will wonder why the vacuum hose is getting shorter and the car in front is getting closer!! As you can guess I learned the hard way
2. Fits in the hole in the lower hinge bracket. Make sure it drops all the way down on windy days. If not, it stops it blowing back but breaks the lower hinge trim.
