Hi all,
I recently put a thread on here about the problems I'm having with my surf and the wheels not engaging when I pull away, (I think it was called 4WD). I was advised that it was more than likely the gearbox, so I had a gearbox fitted, after driving it around for a while the exact same problem came back. I thought I had been supplied with a dodgy gearbox, so I had another one sent down and had it fitted but the problem is still there. When I drive around for a while the wheels don't seem to want to engage, its fine when its cold only happens when the ATF has warmed up.
I spoke to someone who owns a 4X4 and he said that it could be the torque converter. Does that sound about right or what else could be causing this mind numbing problem. If it is the torque converter how much do they normally go for?
Please can someone shed some light on this problem.
