2" Lift
  • 2" Lift
    Toying with the idea of machining up a set of spring spacers and sneaking them on while the missus aint looking. I've checked out the available kits and they seem to come with uprated torsion bars and extended shocks. Dont really want to lose the shocks if I can help it as I find the adjustable setting usefull. I can machine some upper or lower shock body extensions to compensate, but will there be enough travel on the shocks to deal with a 2"lift? I know Check straps are an option to avoid ripping them apart with exaggerated axle articulation, but what about compression? Also, how important is an uprated torsion bar?
    My karma ran over my dogma ..
    Paul
    hi.i put the 2" lift from roughtrax on my old 2.4 and to tell the truth it was a waste of time putting the torsion bars on for a 2" lift as i found the a sod to fit but never noticed any differance.why not just get some spring spacers and keep the original shocks.you wont get much drop on the shocks if your going to off road at all but just for road use it will be ok.Jotto does the spring spacers i think for about £85 + p&p.Hope this is of some help
      Thanks Richard, yes its a great help. I may still machine the spacers myself, and if the standard shocks have enought travel to deal with the lift then the less work, the better! Ive seen that some of you fit landcruiser rear springs and say that it give about 3" lift at the back. Could that be coupled to fitting spacers on the front only?
      Paul
        Spacers on the front for what?
          for whatever the chassis sits on that forms the front suspension. To be honest Ive never looked under there (too preoccupied with the head) but I always presumed that there was suspension of some kind that could be raised/lowered by the addition/subtraction of components. Am I showing my ignorance?
          Paul
            the front suspension is done on torsion bars which you will need to crank up.i have a total of just over 5" lift on the rear and thats with L/c springs and 2" bodylift aswell the front it is about 4" as i have cranked the torsion bars 2" but i would like to get some ball joint spacers for the front aswell (so if anyone knows someone that can make them at a good price)
              Torsion bars control the height at the front. The only time spacers are generally used on the front are for the ball joints. They are used merely to stop the C.V's being pushed to their limit.
                this is what it will look like with L/C springs and the front cranked up with a 2" bodylift also
                  Yeah, look a twit now. Just found the link on how its done when I had the brainwave th do a forum search on 'torsion bars.' Wondered why i got no results from 'front springs'. Sorry for being so thick! Can you get 2" on the torsion bar?
                  Paul
                    yea i got 2" on mine on the standard torsion bars but anymore than that and i would go for the uprated ones.
                    here's a pic without the steps on
                      Saw that earlier when i was searching 'suspension lift' . That just looks so cool. Black as well!
                      Paul
                        yes but you will need to fit diff drop spacers to go that far or you will munch the cv's. mines up 1.5 in on the front
                        TeaM BOFA4x4 Mac 2008
                        www.bofa4x4.com
                          What size tyres are fitted on that pic?
                          Paul
                            sorry i have got diff drop spacers but i have yet to fit them
                              front only, or front and back? Do these come with commercially available susp. lift kits, or seperately? Or is it something you have to run off yourself?
                              Paul
