Hiya
whats the maximum allowed wear in rear wheel bearings?
I have had the drums off the back this morning to check brake pads and clean things up a bit and check wear on drums
I was able to push/pull the rear half-shaft in-out about 0.4 to 0.5mm - which I checked using a dial-guage rather than eyeballing it
is this acceptable movement ?
brake pads down to 1.6-2mm, so I guess getting close to replacement time
they seem to wear unevenly, i.e. lower or upper parts have difference amount of wear, looks to me this is due to the way the brake system works, i.e. levering from top
