Does anyone know if I can swap an R150F transmission/ transfer case from a 1990 4RN VZ130 (3.0l V-6 gas) in a 1991 4RN RN130 (2.4l I-4 22RE gas). I know I cannot swap the bellhousings as the R150F has a large 9 bolt bellhousing to transmission pattern & the G58 has a small 9 bolt bellhousing to transmission pattern, but I was wondering if the bellhousing to motor bolt pattern on these 2 bellhousing are the same (the reason I think they might be is that the similar R151F transdmission was used behind the 22RTE setup in the late 80's. Sorry this is not diesel related.
Transmission swap
I'm here!!!!Originally posted by WoodzieWait till about 0730 to 0830ish uk time and he will be on the forum
Knowing my luck he won't be today
Definatly different mate.
Snip from this site (http://www.marks4wd.com) in Oz thats good for swap info....
The Toyota 4-Runner vehicles equipped with the 3.0 litre V6 engine have a different transmission and transfer case to the earlier 4-Runner 4 cylinder vehicles. Although the bolt pattern on the front of the V6 transmission looks similar to the 4 cylinder 4-Runner 5-speed it is definitely not the same, the V6 transmission is considerably stronger.4x4toys.co.uk - Keeping you on and off the road...
