Good afternoon Surf enthusiasts.
To cut a long story short. after running the surf down the motorway and on returning i found that the expansion bottle was quite full so i replaced the rad cap the next day, now the top hose is quite hard to push in when the engine is running is this normal i think it is beacause water boils at a higher temp under pressure and now the expansion tank only fills a little bit now. under inspection of the old rad cap the spring felt a lot weaker than the new one even though they were the same rated pressure. is it now a bit of time for peace of mind.
chris.
chris.
