Good evening
Want to start preparing for the annual vacation down to south of Spain and this time i dont want any problems eg overheating going across the mountains so i have ordered an oil cooler from a company called Kenlow and wanted to replace the thermostat with an earlier opening one is there one available also has any one had much luck with oil coolers on their surfs any other suggestions to aid cooling would be greatly appreciated.
Chris.
Chris.
With regards to the thermostat, stick with what is in there already. Which engine is it? For the 2.4, there is only one temp thermostat as far as I know. For the 3.0, there are several. However, I honestly wouldn't bother. Unless you are running the engine in extreme temperatures or under constant high load, the standard thermo' will keep the engine at it's best operating temperature.
