I started my body lift today.
Didn't get it finished, for reasons I won't go into, but it will be being finished tomorrow..
The rad shroud. It's a bugger to get off, and I've read a post on here about there being a bolt holding the shroud on at the bottom. But... As I'm fitting drop brackets on the rad, surely I don't actually need to remove the shroud at all, do I?
The rad bolts are out, so I'm thinking that when the body is lifted, the fan will help to lower the rad, due to the shroud being there, and it can then be rebolted in place with the drop brackets..
Not missing anything, am I??
