Originally posted by MattF
		I just couldn't face trying it again, only to fail again!!
Running XP, by the way!
 I just hate the thought that it might be something at this end causing your headache. I'm just as finnicky with myself as I am with other people.
 It's unlocked now.
 It's unlocked now.
 Click on the link again to download it. Both IE and Mozilla/Firefox cache downloads, so it should resume from where it left off, unless you've flushed it's cache.
 Click on the link again to download it. Both IE and Mozilla/Firefox cache downloads, so it should resume from where it left off, unless you've flushed it's cache.  (BTW, you timed out on it
 (BTW, you timed out on it  ).
), , so the separate files are the download now. (Mark, that url you used before is still active, just not listed on the index page, if you still want to try resuming the download).
, so the separate files are the download now. (Mark, that url you used before is still active, just not listed on the index page, if you still want to try resuming the download).  Largest database zip is under 300M each, so should be easier for those with errant software or connections. (Of which I seem to have found everyone, so far).
  Just wanting to double check seeing as you've completed the process successfully.
 Just wanting to double check seeing as you've completed the process successfully.  Cheers.
 Cheers.
