I got to the service station today , drove upto a pump that said unleaded, drove past to the next one that had unleaded and diesel, got out and for the first time ever started putting unleaded into my 3.0TD . 14 litres of the stuff,the tank was nearly dry and so I topped it up to the brim with diesel. It's been running fine since, even did a 2hr stint off roading, what should I do next , run it all to empty and then top up with fresh diesel , or keep thinning the petrol mix out by topping up every 50 /60 miles with diesel, will it cause any long term damage , and is there anything further I should do / add to make it better
Thanks in advance
Thanks in advance
